Hello Guest it is November 21, 2026, 03:18:40 PM
Author Topic: dspmc with mach3 - output problem  (Read 38221 times)
« on: July 20, 2010, 04:03:11 AM »
Hi!
I have problem with otput0(on the board pin0). When starting axisworks i can control 16 outputs without any problem. When I run mach3 with dspmc plugin, push reset button the output0 goes high. It's strange because i dont have any output assigned in "Port and Pins". It looks like mach3 control this output but i cant find how.
Can you help?
Re: dspmc with mach3 - output problem
« Reply #1 on: July 20, 2010, 05:31:00 AM »
hi AAndreeww
this problem was fixed in early June.  have you downloaded the new plugin? http://www.vitalsystem.com/dspmc
thanks
Rufi
« Reply #2 on: July 22, 2010, 07:41:26 AM »
It works now.
thanks a lot.
I have another question. I'd like to use m7,m8,m9 function. I wrote some VB-code in files m7.m1s......
Files are in good destination. When i run spript from script editor it works good. But when i write m7,m8 or m9 in mdi input nothing hapens.
How can i use my function or edit actually built in??
« Reply #3 on: July 22, 2010, 07:52:42 AM »
I am glad you got it working.  I am not vary familiar with macros.  may be the mach experts who reply to questions in this forum can guide you soon.
regards,
Rufi
« Reply #4 on: July 22, 2010, 01:00:13 PM »
I only need to know how the built in m7,m8,m9(coolant) macros are work and how i can use it to my machine.
« Reply #5 on: July 22, 2010, 04:28:55 PM »
They may be hardwired as part of the Mach base code but I am not sure.
None of my profiles have them in it so I would assume they are hardwired.
Mike
« Reply #6 on: August 13, 2010, 03:30:45 PM »
Hi!
I solved my problem. In tab "Port and Pins" >> "Spindle Setup" I set the port for my connection to dsp module.
Then I create a brain which contain open contact "Mist On" and other important for my machine.
