Hello Guest it is November 13, 2026, 01:17:36 PM
Author Topic: switching X and Y axis  (Read 10112 times)
Offline xaco
  •  26 26
« on: July 19, 2010, 03:49:22 AM »
hello, i have my 4th axis aligned with Y that makes me problems to make g-code...so i want to swich  my X axis to become y and Y to become x axis so  my 4th axis would become aligned with x-axis... my 4th axis  is heavy so i dont want to  move it to current  x axis but i rather fix it  outside machine  and let spindle move in current y direction.. so i wonder,can i do this in mach3? where i can switch those 2 axis? beginer here...thank you
Offline xaco
  •  26 26
Re: switching X and Y axis
« Reply #1 on: July 19, 2010, 04:21:41 AM »
this is my current situation if this helps..
« Reply #2 on: July 19, 2010, 07:07:15 AM »
Not sure if I am understanding exactly what you want but if its just that you want the current X axis to move when you ask the Y to and vice versa then change the step and dir pin numbers around.
At the moment you have
X Step 2  X Dir 6
Y Step 3  Y Dir 7
Change them to
X Step 3  X Dir 7
Y Step 2 Y Dir 6
If thats not what you are meaning try again with your explanation.
