Hello Guest it is November 01, 2026, 10:12:55 AM
Author Topic: DXF import fails everytime and gives illegal argument error.  (Read 14590 times)
jerryrigger
« on: October 18, 2006, 02:08:46 PM »
Using Corel Draw and Autocad 2004, I saved my simple square box (also tried simple circle)  in every available version of DXF. (2004,2000, R13,14...) I attempt to bring it into Lazycam and I get an illegal argument error or sometimes just an error box with no description in it.  I downloaded a sample DXF that someone else posted in the forum and it came into Lazycam OK.
I reinstalled Mach3 and Lazycam...same results.  Tried different compute....same results.
Any ideas or tips would be greatly appreaciated.
jr
Re: DXF import fails everytime and gives illegal argument error.
« Reply #1 on: October 18, 2006, 08:23:58 PM »
Post your .dxf here, in V12 format.
jerryrigger
« Reply #2 on: October 19, 2006, 08:07:15 AM »
Someone told me to try R12 format would work and I tried it with success.  Since it is working for me I will not post a file.  I assume that the 2000 and 2004 Acad formatts do not work in Lazy Cam.  If the R12 format works that will be fine.
Thanks for responding.
jerryrigger
« Reply #3 on: October 19, 2006, 12:10:04 PM »
Are you using splines by chance? If so. splines are converted to polylines in V12 .dxf's, but not in newer formats. That may be causing the problem.
The other Sid
« Reply #4 on: November 07, 2006, 11:53:29 PM »
I recently ran into this same problem when trying to import a simple circle.  After a lot of fiddling around to no avail, I added a simple square to my .dxf and everything imported OK into Lazy cam and then I deleted the square in Lcam.  So, I think the problem is importing the arcs/circles???
« Reply #5 on: November 09, 2006, 01:06:50 PM »
That is odd ... I will have to try that.
www.newfangledsolutions.com
www.machsupport.com
