Hello
Guest
it is
November 13, 2026, 09:50:45 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Machine is running in reverse..
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Machine is running in reverse.. (Read 9696 times)
MotoGems
10
on:
July 12, 2010, 02:08:11 AM »
Hello everyone,
Recently the computer died that ran my Super X3 using Mach3 controller...
Swapped computers... loaded Mach3 and Lazycam again... everything seems to be moving fine... EXCEPT... my old programs run in reverse...
Might be OK but Z + is going down.. so that would be a problem...
Is there some config / function config that i have to change???
I'm having difficulties locating something that will help...
Any help is very grateful
Ian
MotoGems.
Logged
Carnoustie, Scotland
Re: Machine is running in reverse..
Reply #1 on:
July 12, 2010, 02:27:02 AM »
You either have the Dir active state set wrong for Z, you will find it Config menu, Ports and Pins, Motor Outputs page
Or you need to change the Reverse setting on Config menu, Homing and Limits page.
Logged
Print
Pages:
1
Go Up
« previous
next »
