Hello Guest it is November 10, 2026, 02:22:57 AM
Author Topic: Modifing Operator Editable Button Macros  (Read 87789 times)
  •  9,376 9,376
Re: Modifing Operator Editable Button Macros
« Reply #30 on: April 20, 2018, 06:34:16 AM »
I have sent you a PM.
Offline TPS
  •  2,627 2,627
« Reply #31 on: April 21, 2018, 12:43:05 AM »
here your modified code, pls test carefully because i have not tested it.
it is just minimal code without any checks like , probe allready grounded when start, or no probe was hit.
Code:
'probe z surface macro
Sub Main()
   FeedCurrent = GetOemDRO(818)   'Get the current settings, OEM DROs (818)=Feedrate DRO
   ZCurrent = GetOemDro(802)      'OEM DROs (802)=Z DRO
   GageH = GetOEMDRO(1001)         'OEMDRO(1001)=Gage Block Height
   ZNew = -300                  'probe down 300 mm
   Code "G90F200"      'slow feed rate to 200 MM/MIN
   Sleep(200)
   Code "G31 Z" &ZNew      'probe Z- 300 mm
   While IsMoving()
      Sleep(10)
   Wend
   ZTouch = GetVar(2002)
   'Go back to point where probe was hit
   code "G0 Z" &ZTouch
   While IsMoving()
      Sleep(10)
   Wend
   'set new z height
   Call SetDro (2,GageH)   'DRO(2)=Z DRO
   FinalMove = GageH + 10
   Code  "G0 Z" &FinalMove
   'return old feedrate
   Code "F" &FeedCurrent   'restore starting feed rate
End Sub
Offline yemil
  •  21 21
« Reply #32 on: April 21, 2018, 07:19:21 AM »
no  it did not..
it  goes down slowly ..touches the plate  and then pushes down hard..
this one is working
                            ZNew = ZCurrent - 300      'probe down 20 mm
                            SetOemDRO(818,200)
                            Rem Code "G4 P1"      'Pause 1 second to give time to position probe plate
                            Code "G31 Z" &ZNew
                            While IsMoving()
                            Sleep(10)
                           Wend
                           SetOemDRO(818,FeedCurrent)
the problem is  that if i modify this for the other 2 axix  X and Y  they work fine if  put them  SEPARATED
if i join X and Y axis Zeroing macros together ,  the machine just senses the first X axis and set it to zero and then ignores the second  part ( just the Zeroing Y axis) it does the rapid movements
' probe x surface macro
XCurrent = GetOemDro(800)   'OEM DROs (800)=X DRO
GageX = -11.5                   'Gage Block x 10 plus 1.5
XNew = XCurrent + 300      'probe to the right
YCurrent = GetOemDro(801)   'OEM DROs (801)=Y DRO
GageY = -11.5         'Gage Block Y 10 plus 1.5
SetOemDRO(818,200)
Code "G4 P1"              'Pause 1 second  to position probe plate
Code "G31 X" &XNew
While IsMoving()
Sleep(10)
Wend
Call SetDro (0,GageX)      'DRO(0)=x DRO
XFinalMove = GageX -10
Code  "G0 X" &XFinalMove
YpreOne = YCurrent-30      ' Y positioning
Code "G0 Y" &YpreOne
Code "G0 X20"
' probe y surface macro
YNew = YCurrent + 300      'probe  on y axis
Code "G31 Y" &YNew      'Y Zero
While IsMoving()
Sleep(10)
Wend
Call SetDro (1,GageY)      'DRO(1)=y DRO
YFinalMove = GageY -10
Code  "G0 Y" &YFinalMove
'Z Position
ZpreOne = ZCurrent +15
Code "G0 Z"&ZpreOne
Code "G0 Y20"
thanks in advance
Offline TPS
  •  2,627 2,627
« Reply #33 on: April 21, 2018, 07:47:17 AM »
put the code in VB Scripter Window step through a see where it Fails.
Offline yemil
  •  21 21
« Reply #34 on: April 21, 2018, 10:59:37 AM »
VB Scripter Window ???
the leaning curve has been so steep.........................
but i did it  and  made some adjustments...
here is the script...  and runs  very well
SetOemDRO(818,200)
Code "G31 X" &XNew
While IsMoving()
Sleep(10)
Wend
Code "G0 Y" &YpreOne      'X en posicion para medir Y
Code "G0 X20"
SetOemDRO(818,200)
Code "G4 P1"
While IsMoving()
Sleep(10)
Wend
'Z Position
Code "G0 Z"&ZpreOne
Code "G0 Y20"          'Y en posicion para medir Z
Znew = ZCurrent-300
SetOemDRO(818,200)
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
Offline yemil
  •  21 21
« Reply #35 on: April 21, 2018, 11:05:44 AM »
i would like to add some adjustments as
diameter of tool
and if is Z zeroing or XYZ Zeroing
« Reply #36 on: April 21, 2018, 11:19:36 AM »
diameter of tool
Congratulations.
I you review the macros in the first two pages of this discussion thread you will see how to add the adjustments for getting tool diameter input and posting status messages on the screen.
airnocker
Everything depends on everything else
Offline yemil
  •  21 21
« Reply #37 on: April 21, 2018, 11:47:47 AM »
i did...
Dim ConfirmReady As String
means   tha ConfirmReady will be letters
and if i want to input  numbers?  like 6..
do i have to tell
Dim ConfirmReady As Integer    ?
« Reply #38 on: April 21, 2018, 08:55:51 PM »
Yes, AskTextQuestion is a means to gather text or numeric input from the user.
I eventually made my AutoToolZero button macro versatile for every variation for what I do on my machine.
Sometimes I want to zero X and Y, then Z and sometimes I find it faster to manually zero X and Y where ultra precision is not required, then only zero Z.  So I built in questions that help remind and error check me, and I use programming numeric "Branch" labels to jump to the appropriate code section based on the response.  Mach3 VB only allows numeric jump points such as (1: or 2: or 3:, etc.) I also ask which touch plate thickness am I using since I have several with different thicknesses, so I'm gathering the adjustment to XY or Z's "zero" value.
Are the touch leads connected (y/n)  (one to the mill bit and one to ground)
If "y" then GoTo 1 Else GoTo 2
Examples from my code.  Bear in mind that you do not use the "If IsSuchSignal (22) Then" since this associates a parallel port interface to Mach3's Ports and Pins configuration.
2:
ToolDia = AskTextQuestion("What is the tool diameter?")
Message( "Auto Zeroing X...")
SetOEMDRO(XaxisDRO, 0.0000)
Sleep 1000
   code "G31 X-2 F10"
   While IsMoving()
   Sleep 100
   Wend
   SetOEMDRO(XaxisDRO, ToolDia/2)
        Sleep 1000
   code "G1 X.5"
End If
Message( "Auto Zeroing Y..." )
SetOEMDRO(YaxisDRO, 0.0000)
Sleep 1000
   code "G31 Y-1 F10"
   While IsMoving()
   Sleep 100
   Wend
   SetOEMDRO(YaxisDRO, ToolDia/2)
   Sleep 1000
   code "G1 Y.5"
End If
3:
DoZ = AskTextQuestion("Position the touch plate to zero Z.  y  to continue or n to skip.  (y/n)")
If DoZ = "y" Then GoTo 4 Else GoTo 6
4:
TouchPlate = AskTextQuestion("Enter Touch Plate thickness: e.g. 0 or .182")
Message( "Auto Zeroing Z..." )
SetOEMDRO(ZaxisDRO, 0.0000)
Sleep 1000
   code "G31 Z-2 F5"
   While IsMoving()
   Sleep 100
   Wend
   SetOEMDRO(ZaxisDRO, TouchPlate)
   Sleep 1000
   code "G1 Z.25"
End If
GoTo 6
5:
Message ("Tool zeroing aborted.  Try again when ready.")
GoTo 7
6:
Message "Tool zeroing complete.  Check the results on the DROs."
7:
End Sub
I hope this helps.
airnocker
« Reply #39 on: April 21, 2018, 10:11:29 PM »
Yemil, do you have the Mach3 Macro manual?  Mach3_V3.x_Macro_Prog_Ref  You can download it from www.machsupport.com under the Product Manuals section here,  http://www.machsupport.com/help-learning/product-manuals/
airnocker
