Hello Guest it is November 22, 2026, 02:45:15 PM
Author Topic: Issue with 3.043.006  (Read 9123 times)
« on: July 06, 2010, 06:54:41 AM »
I tried R3.043.006 but have an issue with it not running a VB script correctly so I attempted to go back to R3.042.040 that runs the Script fine. Now when I press cycle start, the DRO change but the axis's won't move. I believe it has something to do with the Port driver upgrade to the 006 version and then back to 040.
I tried installing the 040 with its port driver when I went back. I assumed it would overwrite any needed files. I did try to shut the computer down and restart, but still no movement with a cycle start. Homes out fine!
Had to go back to 006 to finish the job.
The VB script is just a display of a calculation of the percent done on the Gcode file, so its nothing special.
I'm at a loss  ???
Thanks for any help
Re: Issue with 3.043.006
« Reply #1 on: July 06, 2010, 10:57:49 AM »
Manually remove the driver in Device manager then reinstall .040. That might work.
