Hello Guest it is November 13, 2026, 09:35:19 AM
Author Topic: Trouble with Z-axis  (Read 9456 times)
Trouble with Z-axis
« on: July 05, 2010, 08:13:54 PM »
Hi All,
I am having trouble with my Z-axis. I import the g-code from Visual Mill and the X and Y are milling correctly. I have been jogging the machine and setting the DRO's to zero at the surface of the stock. When I go to run the job, the machine moves above the surface and starts cutting. In display mode, the mill seems to be following the surface correctly. I do notice that the table limits in display mode are below the part I am trying to surface mill. When I change the Z in the config homing/limits so the stock is within the machine bed, it still tries to go up and mill above the surface. Any help would be much appreciated!!
Kory
Re: Trouble with Z-axis
« Reply #1 on: July 08, 2010, 02:36:04 PM »
Sounds like your code is wanting the bottom of the stock to be zero rather than the top. It is certainly conventional to have the top as zero but I believe some router guys do it with the bed as zero.
« Reply #2 on: July 08, 2010, 09:43:55 PM »
Thanks. I think that was the problem. I had to part down in Rhino before exporting to Visual Mill. That seemed to do the trick.
K
