Hello Guest it is November 14, 2026, 04:18:30 PM
Author Topic: glass cutting or etching  (Read 10361 times)
« on: July 02, 2010, 09:55:46 AM »
Does anyone have any info on etching glass on a wood router? I was possibly thinking of trying it for kicks.
  •  9,377 9,377
Re: glass cutting or etching
« Reply #1 on: July 02, 2010, 11:27:14 AM »
I suppose it depends on how much cash you want to spend on your kicks  ;D
I would think the easiest way would be to cut a stencil with your machine stick it to the glass and then lightly sand blast the for the etch (not on or anywhere near the machine  :)  This is vinyl but there is a special stuff made for sandblasting however for light blasting the vinyl works well.
Or you could perhaps add a laser to etch the glass directly.
This is just two options but I am sure there are plenty more. Hope this gives you inspiration.
« Reply #2 on: July 02, 2010, 11:51:19 AM »
Thanks for the info Tweakie! What type of set up did you use for the vinyl cutting?
  •  9,377 9,377
« Reply #3 on: July 02, 2010, 12:41:52 PM »
Made my own cutting knife then any vector toolpath can be used for cutting the vinyl. It's perhaps not as quick as the purpose built machine but it makes just as good a job and it can still be used for routing wood.  ;D
btw. The ready made vinyl drag knives are not that expensive to buy now-days (made in China of course).
There are more details here http://www.cooperman.talktalk.net/files/11.htm
And video here http://www.cooperman.talktalk.net/anelpako.wmv
« Last Edit: July 02, 2010, 12:44:27 PM by Tweakie.CNC »
