Hello Guest it is November 14, 2026, 04:18:45 PM
Author Topic: Toolpath displayed is not what I have programmed  (Read 9434 times)
Offline lesmg
  •  11 11
« on: July 01, 2010, 04:07:16 PM »
Hi There, I have a strange thing happening with my mach3 attached to my cnc machine.
All I want to do is mill out six holes in a line fairly easy, but whne I generate my gcode with CAMBAM and load it in to my machine its wrong see toolpathwrong.jpg wheat I should get is toolpathcorrect.jpg, attached is also the file. I have tried diferent version and nothing changes the correct image is from an0ther machine I use to generate the code, any ideas.
PS If I say cycle start, whatever he toolpath is displayed is what is cut. It seems I think it is the CAMBAM files if I load in other files they are fine. but the same files are correct in my generating machine.
Any ideas???
Les
Offline lesmg
  •  11 11
Re: Toolpath displayed is not what I have programmed
« Reply #1 on: July 01, 2010, 04:19:07 PM »
Ahh found it, IJ mode in MACH3 need to be incremental.
