Hello Guest it is November 13, 2026, 03:42:07 PM
Author Topic: Is anyone else using E1P1 / E1P0 to switch output #1 ?  (Read 56013 times)
Re: Is anyone else using E1P1 / E1P0 to switch output #1 ?
« Reply #30 on: July 05, 2010, 11:48:56 AM »
HUM that is interesting. Art stated early on that the E1p0/1 was to be ONLY Used on a line by itself. If used on mixed line it would error out as bad code syntax error.
« Reply #31 on: July 08, 2010, 07:35:15 PM »
TWEEKIE, Question on the E1p0(;-)   How are you generating your Gcode for laser???
  •  9,377 9,377
« Reply #32 on: July 09, 2010, 12:30:18 AM »
The example I have been using was created using a Roland engraving program which outputs HPGL, this was then converted to GCode. Then I edit the Z moves to the E1P0....
« Reply #33 on: July 09, 2010, 04:38:40 PM »
OK Thanks, I found a slight M5 delay in sheetcam gcode output and was wondering if you were useing that.
