Hello Guest it is November 22, 2026, 07:26:56 AM
Author Topic: help with DC DC converter  (Read 16469 times)
« on: June 25, 2010, 10:24:11 AM »
hi,
I am fortunate to have a dc dc converter  :D to minimize the noise in the system
but I did not find how to connect ???
here is the datasheet of the  main element "AFC5"
 is that someone can help me to connect
thank you in advance
  •  9,378 9,378
Re: help with DC DC converter
« Reply #1 on: June 25, 2010, 10:39:53 AM »
What do you hope to achieve by using the device please ?.
It appears to be a serial / parallel or parallel / serial converter of some sort but I am uncertain of it's application.
« Reply #2 on: June 25, 2010, 04:32:34 PM »
hi tweakie,
it's destinate to decrease noise and i have taked it from a professional cnc machine
  •  9,378 9,378
« Reply #3 on: June 26, 2010, 12:09:20 AM »
Thanks for the explanation, I understand now.
Do you have noise on the drive signals, limit switch inputs or the power lines ?.
« Reply #4 on: June 26, 2010, 04:08:57 AM »
No Tweakie for the moment i have not noise.
One time it happened that X axis made unexpected movement..!!
The manufacturer said that this system is designed to keep very low noise, so i think that is professional to have "AFC5".
  •  9,378 9,378
« Reply #5 on: June 26, 2010, 11:03:59 AM »
Hi again,
I have searched the internet for more info on this assembled AFC5 device of yours without success.
My suggestion is that you forget about it - a dc to dc converter in itself would do little if anything to reduce any electrical noise in a CNC system anyway. If you feel that you have a noise problem then some very good tips have been detailed by Bob Warfield both here http://www.cnccookbook.com/CCCNCNoise.html as well as on this forum.
Sorry I can't be of more help.
Best regards,
« Reply #6 on: June 28, 2010, 05:43:07 PM »
Thanks Tweakie...
