Hello Guest it is October 22, 2026, 04:49:41 PM
Author Topic: Jog VS G00 Performance  (Read 9657 times)
« on: June 24, 2010, 03:29:14 PM »
With a jog we can easily get 50 IPM, with G00 best we can do is 17 IPM! Any suggestions what could cause this and how to fix.
Thanks!
Shane
Re: Jog VS G00 Performance
« Reply #1 on: June 24, 2010, 08:28:41 PM »
If i recall corrrectly you are limited by the max velocity, so when jogging at 100% or G0 (a rapid move) you can go only to max velocity.
Irrelavant, you would only continuosly jog or rapid at a rate such that you are not missing steps. With steppers anyway....
There is a feedrate can be overiden from 20 to around 300% by putting a percenatge into the DRO, maybe that's what you have and didn't realize it,
but the Led will light up warning you. Same practical comment made above would still apply.
« Reply #2 on: June 26, 2010, 09:16:53 AM »
Check to make sure your rapid (G0) overide is at 100%. As you have noticed JOG and G0 are too different things in mach.
