Hello Guest it is November 21, 2026, 05:54:32 PM
Author Topic: What is the best Cad / Cam software?  (Read 33983 times)
Offline DMBGO
  •  201 201
  • Time is the same in a relative way
« on: October 15, 2006, 07:32:04 PM »
Hi, My name is Dave Maher, I am new to cnc, but have just built a small cnc router. I was wondering what cad / cam software others are using. I work in IT, but am unfamiliar with this area. I am prepared to pay for software if I have to, but need a recommendation as to which package to use. I want to make small parts for the vintage motorcycles that I restore.
Cheers and thanks in advance
David
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: What is the best Cad / Cam software?
« Reply #1 on: October 15, 2006, 10:08:40 PM »
Surfcam is nice, Mastercam is also nice, both are very similar, but either will cost you over $8,000 for the most basic version. Bobcad is good value for money, and there are a few cheaper ones out there as well, if you only need 2.5 axis stuff.
ynneb
« Reply #2 on: October 16, 2006, 03:19:42 AM »
Try SheetCam for very ecconomical 2.5 D work $160 I think.
Lazy Cam, that comes free with Mach3, is also coming of age.
Check out here http://www.machsupport.com/cam.htm
« Last Edit: October 16, 2006, 05:57:11 AM by ynneb »
« Reply #3 on: October 16, 2006, 06:59:21 AM »
I have only used one prorgram, it is artcam. Check them out, I think they have cheaper versions. It is real good for graphics.
Offline PaulWC
  •  125 125
« Reply #4 on: October 16, 2006, 07:59:51 AM »
Hi Benny,
Here's one you might add to the CAM page... it has similar features to Code Shark's Editor:
http://www.jssmdx.com/Products/MDXEdit.htm
Paul, Central OR
« Last Edit: October 16, 2006, 09:05:04 AM by PaulWC »
Yodawill2000
« Reply #5 on: October 16, 2006, 08:26:47 AM »
Paul.
Any idea what that app cost ?
Offline PaulWC
  •  125 125
« Reply #6 on: October 16, 2006, 08:55:46 AM »
Down the page, next to the "Download Trial Versions" are red buttons for $20 (End User Version) and $99 (SDK Version).
Might be a real nice editor for Mach3 integration?
By the way... I have no affiliation.
Paul, Central OR
Yodawill2000
« Reply #7 on: October 16, 2006, 09:22:21 AM »
Saw those but wasnt sure. Thanks.
Sure Wish LCam could "create" a part , instead of modifying an existing drawing.  :-[
Offline PaulWC
  •  125 125
« Reply #8 on: October 16, 2006, 12:57:07 PM »
There are so many affordable CAD programs out there, I doubt it would be worth the effort to build it into LazyCAM.
I use TurboCAD Deluxe for my designing with good results in 2D and 3D... 3D is great for visualizing the finished part/assembly. My avatar is a TurboCAD 3D image, rendered in Carrara.
Version 11.2 is available from Purplus for just $29.95:
http://store.purplus.net/tudeve11.html
No affiliation... just a happy customer.
Paul, Central OR
« Last Edit: October 16, 2006, 12:59:07 PM by PaulWC »
Yodawill2000
« Reply #9 on: October 16, 2006, 01:46:53 PM »
Will TC 11.2 save as a dwg/dxf format ?
