Hello Guest it is October 22, 2026, 02:43:56 PM
Author Topic: Problems Setting Home limits, table size etc  (Read 9858 times)
« on: June 21, 2010, 04:56:05 PM »
HI All,
I am running through the setup of my home limits, table size for the first time and seem to need some assistance. I have viewed the online video which was some help, but still having some problems.
I have all three home switches functioning properly, inputs configured and working.
A few questions:
   Can I tell just a single axis to go "home" to test it out before tackling the other axis?
   When I manually jog the table to home and all three home switches activate, how to I tell Mach3 that this is Home.
   My DRO's seem to be reading twice the actual table movement ie" I get a DRO reading of 72 for 36" of actual table movement.
My table is 36x36 with a 5" Z axis
Any assistance would be appreciated.
Castleworks
Re: Problems Setting Home limits, table size etc
« Reply #1 on: June 24, 2010, 03:31:41 PM »
If your Mach3 "Scale DROs" are all set to 1.000 then chances are you don't have the Motor Tuning "Steps per unit" set properly.
airnocker
Everything depends on everything else
« Reply #2 on: June 24, 2010, 05:04:49 PM »
Diagnostics page, top left .
Ref X
Ref Y
Ref Z
etc.
Doesn't work that way. You need to use the Ref buttons to home. Once you do that, then Mach knows where home is.
double your steps/unit in motor tuning.
