Hello Guest it is October 21, 2026, 11:48:20 AM
Author Topic: USB connection in win7  (Read 15127 times)
« on: June 21, 2010, 11:14:52 AM »
Hi I just got my CNC table and am running mach3 through a laptop with no parallel port. In searching the forums I saw that mach3 will not work with a USB connection. Is this actually the case? Is there a work around for this? Thanx for any help yall can give.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: USB connection in win7
« Reply #1 on: June 21, 2010, 02:57:30 PM »
You need an external motion controller card to run your machine over USB. I use/sell the SmoothStepper and find it works great. It supports about 95% of the functionality of the parallel port driver. http://soigeneris.com/Warp9.aspx
Happy machining , Jeff Birt
« Reply #2 on: June 22, 2010, 08:13:19 AM »
How does this hook up? I have a Taig cnc mill. I know you need to plug it into the computer but can that be accomplished with a USB cable? Is the output a printer type parallel cord?
Thanx much
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: June 22, 2010, 08:38:15 AM »
You plug a USB cable in between the computer and SmoothStepper. Ports 1&2 on the SmoothStepper are deigned to be Pin by Pin compatible with a standard parallel port, you use the LPH26 to DB25 cable to convert the SmoothStepper 26 pin header sockets into a regular parallel port cable connector. There is a driver and Mach plug-in that you install.
« Reply #4 on: July 09, 2010, 09:32:46 PM »
Jeff, could you please clarify what 5% of the Mach 3 functions do not work with the USB adapter?
Carlos
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: July 09, 2010, 10:35:19 PM »
What I know of: Backlash control, SwapAxis, Plasma torch height control.
