Hello
Guest
it is
November 10, 2026, 01:58:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
VB and the development of wizards
How to run a script after each Gcode in single step mode
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: How to run a script after each Gcode in single step mode (Read 23608 times)
zafarsalam
338
Re: How to run a script after each Gcode in single step mode
Reply #10 on:
June 28, 2010, 08:53:26 AM »
I retrofit a punch press last year
http://www.machsupport.com/forum/index.php/topic,11844.msg75764.html#msg75764
. I programmed a macro for punching (M20) and put it manually to the end of each line of G0 commands created with drill cycles. I use Excel spreadsheet to edit and put M20 after each line. Just a matter of cut and paste. Takes less than a minute.
Zafar
Logged
lfleiva
33
Reply #11 on:
June 30, 2010, 10:38:22 AM »
Hi Zafar,
Thanks for your tip!
I like the screen, is it your design? Could I use it for a fee?
I was thinking to use the plasma screen.
Luis
Logged
zafarsalam
338
Reply #12 on:
July 01, 2010, 01:40:11 AM »
Luis,
Yes I designed the screens. Here's a snapshot of the screens. Do you need just the screens or the macros too. PM me or contact me direct at zafar@zafar.com.pk
Zafar
Logged
Print
Pages:
1
2
Go Up
« previous
next »
