Hello Guest it is October 22, 2026, 05:54:17 PM
Author Topic: Paralell port trouble  (Read 27349 times)
Re: Paralell port trouble
« Reply #10 on: June 18, 2010, 12:34:27 PM »
So address should be 378,
Have a look in Bios and see what mode it is set to, been a long time since I used a PP but think EPP is best if I recall.
Offline mr.c
  •  40 40
« Reply #11 on: June 18, 2010, 12:43:37 PM »
You do need to check your cable. A printer cable will operate your printer but it may not have wires for every pin. You need a data cable that have all the pins wired.
Offline mrpeja
  •  114 114
    • Embroidery Machines
« Reply #12 on: June 18, 2010, 02:23:40 PM »
I have set standard port. Tomorrow I'll try EPP mode.
Also, I have bougt parallel data cable, but for sure, I'll examine it tomorrow.
Hood, if you are online, can we chat?
Offline mrpeja
  •  114 114
« Reply #13 on: June 18, 2010, 02:36:59 PM »
I think I discovered the source of the problem. When I unplug printer cable and observe Diagnostic screen in Mach, then I see changes. So, parallel port is working good. It must be a problem with my breakboard. I'll se tomorrow,
Regards to all
« Reply #14 on: June 21, 2010, 06:24:52 PM »
Remove the printer driver. Deactivate the print spooler.
Offline mrpeja
  •  114 114
« Reply #15 on: June 22, 2010, 02:43:13 PM »
Hi simpson36,
Which one printer driver to remove? Windows or Mach?
« Reply #16 on: June 22, 2010, 03:44:09 PM »
Windows printer drivers can take over the port and will typically poll the port either occasionally or constantly (Epson is particularly bad) to determine if the printer is still attached, needs ink, etc. If your print spooler has anything in it waiting to print, (or sometimes even if it doesn't) it will also poke its head in to see what's going on with the port.
These activities can interfere with Mach's port driver. Many people have posted here that removing a printer driver cleared up a random port problem, and it stands to reason considergin how the PC communicates internally.
Offline mrpeja
  •  114 114
« Reply #17 on: June 23, 2010, 07:46:56 AM »
Hi folks,
thanks for your efforts.
My problem was malfunction of breakboard (DIY)
Regards
Offline mrpeja
  •  114 114
« Reply #18 on: June 23, 2010, 08:31:17 AM »
Another question,
Which Parallel port mode is the best for Mach3 CNC controll?
SPP, EPP or ECP?
