Hello
Guest
it is
October 22, 2026, 04:50:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
re: Mach 3 updates nice to know
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: re: Mach 3 updates nice to know (Read 13490 times)
DennisF
388
on:
June 17, 2010, 01:05:29 PM »
I recently updated to the latest version of Mach 3 i run a mill and lathe with Mach what i think would great is to have along with the update what it fixes like corrects bug in arc move ETC .
Recently when i updated to the latest version of Mach on the lathe the G-code was all out of whack and these were files i had already cut so i know there were no problems before the update i had to remove the update and all it's files and then go backwards from 2.63 up to get my files working again letting us know what the update dose may save some time and work would be great if possible.
Dennis
Logged
Carnoustie, Scotland
Re: re: Mach 3 updates nice to know
Reply #1 on:
June 17, 2010, 01:19:47 PM »
As far as I am aware there has not been any Turn specific work been done in Mach so I am unsure why you would have problems.
What were the problems you had?
Logged
DennisF
388
Reply #2 on:
June 17, 2010, 01:24:18 PM »
Hi Hood
Thanks for your reply, after the update the arc's turned into circles and and figure 8's going backwards to earlier version's thankfully i saved them i was able to get the files back on line.
Dennis
Logged
Reply #3 on:
June 17, 2010, 01:26:06 PM »
Sounds like your setting for Reversed Arcs In Front Toolpost somehow got changed.
Last Edit: June 17, 2010, 01:28:57 PM by Hood
Logged
DennisF
388
Reply #4 on:
June 17, 2010, 01:38:01 PM »
If that's so then why when going back to an earlier version of mach would it correct itself? oh and i am not using LT the roughing is so so the finish starts backward rear to front.
Dennis
Logged
ger21
6,295
Reply #5 on:
June 17, 2010, 01:39:42 PM »
Is this what you're looking for?
http://www.machsupport.com/downloads/Changelist90.txt
Logged
DennisF
388
Reply #6 on:
June 17, 2010, 05:04:50 PM »
Yes it's a help i am trying to again update my Mach version and did not write down the one i was using that worked, i will take all the help i can get.
Dennis
Logged
Print
Pages:
1
Go Up
« previous
next »
