Hello Guest it is November 21, 2026, 03:54:41 AM
Author Topic: E-stops and failure to get steppers to move...  (Read 10140 times)
« on: June 15, 2010, 02:41:00 PM »
New to the forum and Mach. I hope to have time to introduce myself properly later.
I am building a CNC router based on  JGRO's design off the CNC Zone Andhave build my own stepper board off Instructables...found here
http://www.instructables.com/id/Parallel-Port-3-Axis-CNC-Driver-Opto-Isolated/step2/Resistors-and-Diodes/
I have managed to wire it all up and get it working in K-CAM but I would really like to use Mach (which I plan to purchase once I have got the CNC tweaked enough to warrant it). I downloaded the trial and followed the video and read through the guide but still cant get the motors to turn in Mach. Is this because I have no E-stop switch (something not clear in both the guide or video)?
If so is there a way to bypass this either using the software or shorting a couple of pins on my board? whilst I know this is not really very safe my plan is to build my own revised board after I have got a proof of concept...
thankyou in advacne
Re: E-stops and failure to get steppers to move...
« Reply #1 on: June 15, 2010, 02:46:14 PM »
Is the Reset flashing, or is there an error message? If the reset won't go off, toggle the active low setting in ports and pins.
« Reply #2 on: June 15, 2010, 02:56:12 PM »
Hi, thanks for the fast response... I did all that like it said in the video and guide which I assumed was the software workarround.)
Still no Joy... (Is still the right word?  hmmm...)
Anyhow any other ideas woul be great...
Oh and no errors either... As far as I can tell the Mach is working fine but just not with my board....
But like I say board works okay in K-CAM
thanks,
« Last Edit: June 15, 2010, 02:58:11 PM by No-one »
« Reply #3 on: June 15, 2010, 04:38:16 PM »
Wrong port address, or wrong port assigned to pins
« Reply #4 on: June 17, 2010, 01:22:43 PM »
I am an idiot, Thanks. I forgot to assign the pins a port :)...
Thanks once Again :)
