Hello Guest it is November 22, 2026, 02:53:40 PM
Author Topic: Z axis G1 moves get shorter with reduced feed rate  (Read 24615 times)
Re: Z axis G1 moves get shorter with reduced feed rate
« Reply #10 on: June 18, 2010, 04:42:47 PM »
Sounds like something is tight and the slow speed is causing lost steps.
« Reply #11 on: June 18, 2010, 07:31:55 PM »
Tend to agree with Gerry and Hood that it is mechanicaly related.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: June 19, 2010, 03:45:24 AM »
what microstepping value are your drivers set to?
Ian
« Reply #13 on: June 24, 2010, 03:40:37 PM »
Just a thought, did you run "Drive Test" on the 2nd PC after Mach3 installed and rebooted?
airnocker
Everything depends on everything else
« Reply #14 on: July 06, 2010, 02:38:54 PM »
SOLVED!
You guys were quite correct, it was mechanical. I found some tightness in the new leadscrew.
I've cured that and also upped the gear ratio on the Z axis.
Thanks for all your help.
