Hello Guest it is November 27, 2026, 07:44:25 AM
Author Topic: Wiring Limit, Home and E-Stop Switches  (Read 118116 times)
Re: Wiring Limit, Home and E-Stop Switches
« Reply #30 on: March 12, 2016, 04:34:34 AM »
My axis are all configured. I have already tuned them.
« Reply #31 on: March 12, 2016, 04:40:25 AM »
My z is working fine now. My y when I home and it hits the limit it automatically changes polarity
  •  9,379 9,379
« Reply #32 on: March 12, 2016, 04:56:02 AM »
Could you have posted the wrong .xml ?
This is certainly not right for the Z axis config.
« Reply #33 on: March 12, 2016, 04:57:44 AM »
I reloaded mach3
  •  9,379 9,379
« Reply #34 on: March 12, 2016, 05:10:24 AM »
I reloaded mach3
Perhaps re-post your .xml file (the one from your Mach3 folder) now that you have reloaded Mach3. Copy and rename it to kharrison2.xml for posting.
« Reply #35 on: March 12, 2016, 08:09:48 PM »
I just spent 4 hours but I got it all working really good
  •  9,379 9,379
« Reply #36 on: March 13, 2016, 12:34:37 AM »
Excellent  :)
« Reply #37 on: March 13, 2016, 09:36:36 AM »
The only thing I don't know is how to calibrate the a axis. If I should be using inches or degrees of turn and how to set that up
« Reply #38 on: March 19, 2016, 06:03:03 AM »
I went to call the a axis I put a level in the chuck.  I entered 1 and it turned 3y0 degrees.  Is this right
« Reply #39 on: March 27, 2016, 07:18:44 PM »
Hi I got the cnc up and running. I used my bobcad v26 to write a G code so I can face mill my cnc bed to flatten it. When I go to run the g code in mach3 it wants to go away up in z t5 or better for no reason. It is supposed to start cutting at -.001. Can anyone tell me what I got set wrong or what is happening
