Hello Guest it is November 27, 2026, 07:44:26 AM
Author Topic: Wiring Limit, Home and E-Stop Switches  (Read 118116 times)
Re: Wiring Limit, Home and E-Stop Switches
« Reply #20 on: March 04, 2016, 03:14:24 PM »
Can you please send me a link to the xml backup folder
  •  9,379 9,379
« Reply #21 on: March 05, 2016, 12:51:40 AM »
Typically...
C:/Mach3/xmlbackups
« Reply #22 on: March 08, 2016, 05:51:03 AM »
How do I  choose which 1
  •  9,379 9,379
« Reply #23 on: March 08, 2016, 07:08:38 AM »
Go back to a time when you believe Mach3 was working correctly.
« Reply #24 on: March 08, 2016, 09:03:33 PM »
Just got my new 6040 CNC. Setting up Mach3. I have all the limits for the table set up. But when I go to do my first g code load the Gcode is at the bottom left but my table works space is offset ? I am lost tried to play around with it and used YouTube but nothing could tell me how to adjust. Anyone want to help a newbie out. Thanks again. BRNDAIR
« Reply #25 on: March 10, 2016, 04:26:00 AM »
Hi Tweaking.  I had my computer tech try to load a xml file with some improvement but it's now rite. So tonight he is going to take mach3 off and reinstall it.
« Reply #26 on: March 11, 2016, 04:30:24 AM »
Ok we tried the xlm and it brought back the z dro but the z- won't work . Yesterday we reloaded mach3 and my z works fine. But now when I  ref all home the z works fine but the y axis when it hits the home button it slowly starts to move in the + direction. So I hit the stop. When I go to do it again it has inverted from low to high so I have to go and change the imputed signal to get it going the right way. The x axis is the same.  Where do I go next.
  •  9,379 9,379
« Reply #27 on: March 11, 2016, 04:44:40 AM »
Post your .xml file ( the current one from you Mach3 folder ) copy and rename it to something unique (kharrison.xml) then use the Reply and Additional Options tabs to attach it.
We will then be able to check your settings and perhaps be able to suggest the way forward.
« Reply #28 on: March 11, 2016, 08:22:50 PM »
Ok great. Here it is.
  •  9,379 9,379
« Reply #29 on: March 12, 2016, 12:50:49 AM »
I will look at it in more detail but from initial observation...
In Config. / Motor Tuning you need to set Steps Per Unit, Velocity and Acceleration for your Z axis.
