Hello Guest it is October 22, 2026, 02:44:05 PM
Author Topic: Driver test and motor tuning not working  (Read 10381 times)
« on: June 12, 2010, 06:19:43 PM »
Yesterday I as doing some cutting and the machine and computer stopped communicating. I talked to the company that made the machine and they said it sounded like a mach3 issue. I tried to run a driver test and nothing happened, same thing when I tried to check the motor tuning, nothing. I reloaded mach3 and they both worked fine, I loaded the xml for my machine and tried to jog the machine in the x and y axis and it is like they are both stuck on something (z is still working) so I tried to use the driver test again. No-go same with motor tuning they don't come up no matter how many times you click on them.  I am going to reload xp on my shop computer to see if that solves the problem. Any other suggestions?
I just recieved a new gecko drive for the x because the other one got a metal shaving in it some how and blew up.  So one of the first things that I did when the axis' stopped working was make sure they were both clean and there are no problems there.
Nick Chirstensen
Little Sapling Toys
Re: Driver test and motor tuning not working
« Reply #1 on: June 12, 2010, 06:47:14 PM »
Can you attach the xml please.
« Reply #2 on: June 12, 2010, 09:31:05 PM »
I tried to attach the XML but it told me that there was already a file by that name on here?... Also where is the attach files button, or do you just press post after you browse for the file? Anyway, I tried to hook up the machine to another computer and still the same results. My friend helped me to figure out the driver test thing it seems that I moved the mach 3 folder instead of shortcutting it. That makes me think that I should try some other things a well.
The machine is a Romaxx HS-1 running the 300ipm XML.
Nick
« Reply #3 on: June 13, 2010, 01:53:28 AM »
rename your .XML to another name and then attach it
**Even a clock that does not work is right twice a day**
