Hello Guest it is November 13, 2026, 10:43:53 PM
Author Topic: select case  (Read 7914 times)
Offline Bill_O
  •  616 616
select case
« on: June 03, 2010, 04:21:02 PM »
I am writing a macro and wanted to know if while using select case I can use strings instead of numbers?
Bill
Re: select case
« Reply #1 on: August 24, 2010, 03:59:49 PM »
wooow!
"if", "while", "select" and "case" in same sentence!! Looks like a script! =D
- You CAN'T use STRINGS with select case.
- You CAN use only INTEGER or CHAR with select case.
Why you need use strings on select case?? Normally char its more useful.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: select case
« Reply #2 on: September 02, 2010, 04:33:45 AM »
wooow!
Nice one  ;D
However, sorry but you CAN use strings in a select case - not very well explained in the Cypress UG but...
