Hello Guest it is November 07, 2026, 09:52:49 PM
Author Topic: searching home  (Read 9701 times)
searching home
« on: June 03, 2010, 03:57:29 AM »
This is my first post.
I am a beginner and I am retrofitting an old mill with servos and now controlled by a Galil DMC-2100. I have set up the PID speed and acc parameters in Galil tools and there it works fine, but I want to use Mach3. I set the port and pins for homes and limits but where the signal for motor enable (AMPEN) is always low. By the moment, I jump that signal.
I checked the limits and home in the diagnosis screen and works fine. But now the second trouble (maybe related with the first one) When I search home it doesnt stop, even in when it active the limit swich it doesnt stop either. In Galili tools searching homes was done fine....
I am confused and i dont know what to try. Any ideas?
thank you so much.
