Hello Guest it is October 30, 2026, 03:01:18 PM
Author Topic: Jerky movement  (Read 10103 times)
Jerky movement
« on: June 01, 2010, 04:48:09 PM »
   Hello,
I have a problem with machine controlled by Mach3 software. When you run a NC file, the movement of the machine along a curve is jerky. On the straight lines is smooth. The NC file was generated from ArtCAM. I tried postprocessors for arcs and for straight lines, but the result is identical. The attached is a sample NC files and screenshot of motor tuning (everything is in millimeters.).
    Would you help me solve this problem?
Re: Jerky movement
« Reply #1 on: June 01, 2010, 05:12:21 PM »
As a test try with the circular pocket wizard and see if things are jerky.
Re: Jerky movement
« Reply #2 on: June 01, 2010, 05:33:52 PM »
Also verify that the machine is running in G64 mode(CV) and not G61mode(exact stop). Normally in the header of the Gcode file it would set the mode correctly. But I don't see it in yours
Just thought
