Hello Guest it is October 30, 2026, 11:51:21 AM
Author Topic: Problem with Zeroing X, Y, Z after homing.  (Read 10720 times)
« on: May 29, 2010, 07:09:53 AM »
I am using version R3.042.029.  Lately when I click on Ref All Home, the X, Y and Z are not set to zero after it has completed homing the system.  I do have the Auto Zero checked in the Home / SoftLimits Config page for each axis.  What could be the problem.
Re: Problem with Zeroing X, Y, Z after homing.
« Reply #1 on: May 29, 2010, 07:21:40 AM »
Does it home correctly other than not zeroing
If no do you get a reset and/or any message in the ticker window?
If yes then make sure you dont have a home off value set for the axis.
Failing all that try disabling Auto Zero, close Mach and restart Mach then set back to Auto Zero and again shut down and restart Mach and see if that helps.
« Reply #2 on: May 29, 2010, 08:29:40 AM »
Hood,
The system has been correctly finding home.  I do not have any Home Off Values set.
I did what you suggested and that appears to have fixed the problem.  I will see what happens over the next few days.
Thanks for the suggestion.
« Reply #3 on: May 29, 2010, 11:11:08 AM »
Hopefully it will stay working, if not might be an idea to try a reinstall of the version you have.
