Hello Guest it is November 10, 2026, 01:55:41 AM
Author Topic: start from line #  (Read 40552 times)
start from line #
« on: May 29, 2010, 05:41:31 AM »
i want sense M3(when Spindle turn on) and save "Line number" to var 604.
and show number line to userDRO 1200.
if i trigger input#1 then code execute from it line.
1140 is OEMled for input#1
i write this VB code in addition about VB i am very Beginner :)  :
macropump.m1s
If DOSPINCW()
then
SetVar(604,GetDro(16))
SetUserDro(1200,Getvar(604))
END if
A = GetOEMled (1140)
B = GetUserDRO (1140)
If A And (B = 0) Then
SetDro(16,Getvar(604))
Sleep(100)
DoButton(0)
SetUserDRO(1140,1)
End If
If Not A And (B > 0) Then
SetUserDRO(1140,0)
End If
plese guide for Troubleshooting.
« Last Edit: May 29, 2010, 05:46:05 AM by manmardam »
**Even a clock that does not work is right twice a day**
Re: start from line #
« Reply #1 on: May 29, 2010, 06:07:36 AM »
sorry for my mistake.
correct line1 :
C = GetOEMled (11)
If C  THEN
« Last Edit: May 29, 2010, 06:14:20 AM by manmardam »
« Reply #2 on: May 30, 2010, 10:46:19 AM »
OK I see a BIG safety concern. The macropump updates 10 times per sec SO it is really a continuos loop.
It is a bad idea to have statements(DoButton(0)) that control machine movement from the macropump AS it could cause  the machine to move without being under the Direct control of the operator. It could injure or kill the operator.
« Reply #3 on: May 31, 2010, 01:57:56 AM »
i write this code and work well:
macropump.m1s
C = GetOEMled (813)   ' Dwell LED
D = GetOEMled (11)     ' Spindle ON LED
If C And D Then
End If
      'in fact C & D sense "M03" .have You a better suggestion ?
'A = GetOEMled (1140)       / is Inactive because dont work well
'B = GetUserDRO (1140)
'If A And (B = 0) Then
'Code "M115"
'SetUserDRO(1140,1)
'End If
'If Not A And (B > 0) Then
'SetUserDRO(1140,0)
'End If
and
m115.m1s
DoButton(1)                 'Feedhold
While IsMoving      'Wait for movement to stop
Sleep(100)
Wend
DoButton(3)      'Set Stop
Sleep(1000)
SetDro(16,(Getvar(604)+1))
Sleep(100)
DoOEMButton(156)
Sleep(100)
DoButton(0)
END
my problem is when i trigger "INPUT#1" ,dont trigger M115.
please help me.
I use this code when cutting does not do well and we need to be done again
have You a better suggestion?
« Last Edit: May 31, 2010, 02:01:29 AM by manmardam »
« Reply #4 on: May 31, 2010, 12:12:44 PM »
Sorry sport but what you are trying to do is dangerous. You are on your own for this one.
« Reply #5 on: May 31, 2010, 12:14:43 PM »
dangerous
why?
What is important for this forum:
« Last Edit: May 31, 2010, 12:16:20 PM by manmardam »
« Reply #6 on: May 31, 2010, 12:19:09 PM »
Because the operator DOES NOT have primary control of the start of movement of the machine. It could move anytime the conditions exist whether you wanted it to move or not. THAT IS DANGEROUS.
« Last Edit: May 31, 2010, 12:20:50 PM by BR549 »
« Reply #7 on: May 31, 2010, 12:26:40 PM »
no.
you dont understand my mean.
in cutting with OXY/fuel Sometimes Because to being dirty sheets ,cutting surface is not well done. The user can then once again previous path from starting point to begin Counter
does not Any interference in the main process
« Last Edit: May 31, 2010, 12:28:31 PM by manmardam »
« Reply #8 on: May 31, 2010, 12:31:44 PM »
are you have ?
AND
« Reply #9 on: May 31, 2010, 12:49:26 PM »
NO "I " don't
