Hello Guest it is October 22, 2026, 04:49:59 PM
Author Topic: How to start cycle? New to screen design  (Read 14682 times)
« on: May 26, 2010, 01:30:41 PM »
I am new to designing screens with Mach3 and I have made an example for me to work with, but why when I select start cycle it does not go through the G-Code and on the toolpath screen does not show a simulation of whats going on. I set the button to Cycle Start/Run function but its not working. What am I doing wrong? Here is my example file.
Thank You :)
Re: How to start cycle? New to screen design
« Reply #1 on: May 26, 2010, 01:44:43 PM »
You have that button set to OEM 1016
Select "System Function" / RUN
« Reply #2 on: May 26, 2010, 01:47:30 PM »
OEM 1016 is the "Run From Here" function.
« Reply #3 on: May 26, 2010, 01:52:16 PM »
Thank you :).
I was using the software MachScreen V1.42 and not Screen4. I selected Cycle Start in MachScreen but was not working, but working with Screen4 when set to Run. Thanks again :)
« Last Edit: May 26, 2010, 01:53:47 PM by system32 »
« Reply #4 on: May 26, 2010, 01:56:47 PM »
OK, then in MachScreen you would select OEM 1000.
« Reply #5 on: May 27, 2010, 10:56:06 AM »
Do you have a reset button? You'll have to push reset before you can run code.
« Reply #6 on: July 12, 2012, 09:07:59 PM »
I was using the software MachScreen V1.42 and not Screen4. I selected Cycle Start in MachScreen but was not working, but working with Screen4 when set to Run. Thanks again Smiley
Rc Hobby|Rc Helicopter Reviews|Rc Helicopter
