Hello Guest it is November 12, 2026, 12:41:49 AM
Author Topic: Mach3 to not recognize/move the axis while operating the spindle just fine  (Read 12022 times)
This one will be a teaser!
I am using Dared's BOB on a Bridgeport Series II CNC Mill.
The EStop on the mill and in software works just fine.
Also the spindle stops and starts like a champ.
But no axle movement at all.  None of the axis jog, or move while running a program.
MaxCL is enabled.
I think the problem lies in a setting in the software related to MaxCL.  For some unknown reason Mach3 simply isn't telling the axis to move, or possibly even recognizing any axis at all, given that all the axis are grayed out in Motor Tuning.
Jog is enabled with "continuous" set.  The Numlock is off.
I have checked the wiring and it is hooked up right with no breaks.
I am definitely NOT on a limit switch.  The mill bed is dead center and moves fine when the original BOSS control is hooked up.
When running a program, it just skims through all axis movements doing nothing, again leading me to believe Mach3 simply doesn't recognize any of the axis.
When the computer is running, here are the status of the LED's on Darek's board  The LED numbers correspond 1 to 1 with port pin numbers.
1,3,4,5,7,9,14,16,17 are on (lit)
2,6, and all the input's are off (unlit).
Input #10 is lit when the mill is first turned on, and goes off when the Limit Override button is pressed.
I'm stumped.  What would cause Mach3 to not recognize/move the x, y, and z axis while operating the spindle just fine?
What do you suggest?
