Hello
Guest
it is
November 07, 2026, 10:08:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Galil
(Moderators:
smurph
kcrouch
galil and backlash compensation
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: galil and backlash compensation (Read 14806 times)
Cncman2nv
90
on:
May 10, 2010, 07:45:40 AM »
Is there a way to set backlash compensation in mach3 control or the galil controller
Adam
NosmoKing
243
Re: galil and backlash compensation
Reply #1 on:
May 10, 2010, 09:12:27 AM »
There is no command per-se, AFAIK you have to write a routine to do this, there is the MR command that may be able to be used, or there is a Backlash Compensation routine shown in this Galil manual.
http://www.electromate.com/db_support/downloads/ManualV3.pdf
I have not tried it.
Normally on a CNC machine the backlash comp is taken up in one particular direction, when a position is reached and the axis is reversed in the B.L. take up direction, the axis will move at a high rate by the amount of the recorded backlash.
Nosmo.
Reply #2 on:
May 10, 2010, 01:08:26 PM »
Backlash can be set in CONFIG>BACKLASH. As Nosmo reponded it is implemented on change of axis direction.
The backlash settings determine how fast it will be implemented. Works quite well.
NosmoKing
243
Reply #3 on:
May 10, 2010, 01:24:43 PM »
I should have stressed there is no GALIL command per-se.
If Mach has it then obviously you don't need to bother with the other routines.
Nosmo.
Cncman2nv
90
Reply #4 on:
May 10, 2010, 01:29:11 PM »
I don't think the backlash works with the galil plug in installed i tried it but no noticeable difference
Adam
smurph
1,575
"That there... that's an RV."
Reply #5 on:
July 30, 2010, 01:14:43 AM »
The Galil plugin just follows what Mach says. If Mach is correcting for backlash, then the Galil plugin would not hinder it. Test is by setting backlash to some insane value.
Steve
Print
Pages:
1
Go Up
« previous
next »
