Hello Guest it is September 28, 2026, 11:35:17 PM
Author Topic: Jogging with a Joystick  (Read 32439 times)
« on: January 18, 2006, 07:55:28 PM »
Has this feature been disabled in Mach 3?  I can't seem to find any "Joystick enable" button as the instruction manual indicates. ???
Re: Jogging with a Joystick
« Reply #1 on: January 18, 2006, 09:45:03 PM »
Here is a set file that should let you turn on the joystick.
If you need more stuff added I am around.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 19, 2006, 11:19:27 AM »
Hey Brian,
Thanks for the set file!  I installed it and somehow it doesn't seem to be working?  I can see on the settings page where there is now a "joystick Jog" button but, the LED next to it is always on (i.e. clicking on the button doesn't turn it off".]
I'm 99% this is an "operator error" issue so .. how about a little help from the "control tower" please ;)  Thanks!
Sid
« Reply #3 on: January 19, 2006, 02:25:43 PM »
Try this :) I added a few more things and after taking to Art I think I have it...
www.machsupport.com
The Saga continues...
« Reply #4 on: January 20, 2006, 11:32:54 AM »
Hey Brian,
With the new set I now have the on/off jstick buttons which Does make the LED turn on/off but alas- no response from the program when I move my jstick.
The Jog screen pop-up has a blue area above the X,Y,Z jog buttons that says "Button Jog"  should this change when you engage the jstick mode (or is this just a label).
I', pretty sure my jstick is OK because when I go to Control Panel and check the properties for it, there is a test screen andwhen I move the stick, it moves on the screen.
Do I need a special drive for M3??
Thanks for your continued help/patience!
Sid
« Reply #5 on: January 20, 2006, 11:58:49 AM »
I think I am going to have to get a joystick to test it:)
I will get back to you after some testing
www.machsupport.com
« Reply #6 on: January 21, 2006, 01:31:41 AM »
Cool!  Thanks!
« Reply #7 on: February 12, 2006, 04:37:30 AM »
Bump!
« Reply #8 on: February 12, 2006, 06:43:59 AM »
Thank you :)
I can't seem to get to the store :(  I think it is time to do the online thing!
www.machsupport.com
« Reply #9 on: March 16, 2006, 06:41:09 PM »
Bump-  I know this is a trivial thing but it would be nice to have for me (& I hope others too!)
Sid
