Hello
Guest
it is
October 22, 2026, 02:44:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
my computer has no parallel port, please recommend PCI parallel port card
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: my computer has no parallel port, please recommend PCI parallel port card (Read 13473 times)
lucky021
5
on:
April 28, 2010, 03:51:50 PM »
I heard some PCI card didn't work well, so is there any good ones you can recommend? thanks !
I bought the motor kits including the breakout board at Motiotek, does breakout board matter?
Logged
BarryB
267
Re: my computer has no parallel port, please recommend PCI parallel port card
Reply #1 on:
April 30, 2010, 04:23:41 AM »
I'd try the smooth stepper before trying to ho the parallel port route. I've been running my mill off a laptop with a smooth stepper for a while. IMO, it's way easier to debug a smooth stepper setup than to get a couple of parallel ports recognized znd working inside of Mach.
Logged
Garyv
103
Reply #2 on:
June 01, 2010, 06:49:33 PM »
I second what Barry says Lucky, I have been using a smoothstepper for close to a few years now and no problems as of yet and easy to hook up..
Gary
Logged
ger21
6,295
Reply #3 on:
June 01, 2010, 08:59:50 PM »
I'd rather spend $20 to try something rather than $155.
http://www.cnc4pc.com/Store/osc/product_info.php?products_id=250&osCsid=164790ca54eabe87806fda73c0329d5d
Logged
ger21
6,295
Reply #4 on:
June 01, 2010, 09:01:51 PM »
Here's another tested with Mach3.
http://www.candcnc.com/UBOB.htm
Logged
TramAlot
129
Reply #5 on:
June 14, 2010, 12:59:02 PM »
I've use stuff from tiger, see below.
they all seem to work if installed corectly with newer msi mainboards and amd/ati chipsets any way, also most computers have the ports just no connector. look in the bios too see and just buy the header cable(s), they are like 10 dollars. msi has a less common pin conecter for the parrerel but easy to find.....
one other tip is if you need to put more then one board in use differnt manufacturers to keep irq conflicks to a minimum
http://www.tigerdirect.com/applications/SearchTools/search.asp?cat=1422&keywords=pci cards&mnf=2531
serial
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=512
parr
Last Edit: June 14, 2010, 01:03:23 PM by TramAlot
Logged
Print
Pages:
1
Go Up
« previous
next »
