Hello Guest it is October 21, 2026, 03:03:43 PM
Author Topic: FILE/OpenG Code dialog displays after LONG delay?  (Read 8652 times)
« on: April 27, 2010, 02:16:22 PM »
Anybody seen this error?   It takes MINUTES sometimes for the OpenGCode dialog to display.
Re: FILE/OpenG Code dialog displays after LONG delay?
« Reply #1 on: April 27, 2010, 03:48:21 PM »
You may get that if you have loaded an xml to a new computer and the previous location that you loaded files from is not on the new computer but it should only happen the once. If you repeatedly have the problem check that your xml is not read only.
