Hello Guest it is November 22, 2026, 06:45:14 AM
Author Topic: Bit of help needed with VB code  (Read 8910 times)
« on: April 24, 2010, 04:40:58 AM »
Scott S posted some VB parameters and i need help in understanding it a bit.
I want to find the Z offset in lathe for the current tool, Z offset would be parameter 4
Here is the code
GetToolParam(SHORT toolnum, SHORT param)
param { 1 = tool diamter, 2 = ZOffset, 3 = xwear, 3 = zwear )
So that zoffset=(Insert correct VB code here)
Phil
Re: Bit of help needed with VB code
« Reply #1 on: April 25, 2010, 08:20:07 PM »
Using Turn and assuming tool#1 and zoffset
Gettoolparam(1,4)
