Hello Guest it is October 24, 2026, 10:17:05 PM
Author Topic: Spindle control: weird behavior. It never starts at first run, works fine after.  (Read 13696 times)
Offline FXC
  •  45 45
Hi!
Today was the second time I broke an endmill because of this  :'( and it's time to find out out what's going on.
I have a simple setup, with the spindle relay controlled by a PP pin which works fine, no hardware issues here. The problem is software related.
After starting Mach3, loading a program etc., I always have to manually start the spindle (then turn it off) by clicking the Start Spindle button, before running the program; otherwise the M03 command is ignored completely, no matter how many times I try. There are absolutely no issues with subsequent runs, different files, resets or anything else as long as I don't quit Mach3. Again, I only have to do the spindle start once and everything's cool thereafter.
Additional observation: interestingly enough, looking at the G-Code scrolling up during a run, the program doesn't pause at the M3 command at all, whereas it should do so for 1 second (which it does, after the quick fix.) This makes me believe that Mach3 somehow does not execute the command at all.
So the question is... WHY?  ???
Mach3 is a mess.
What version of Mach are you using as I seem to recall a similar issue a few versions back.
Offline FXC
  •  45 45
I just recently set up this spindle relay but it's been a few months since I checked for software updates... anyway, my version is 3.042.033
And now that you brought it up, I went to the changelog page and the very next entry after my version is:
Jan 05/2010
Release 3.042.034
-- Driver Frequency locking in at proper Hz
-- Spindle not turning on bug fixed
-- new Driver test added to show Rev of Driver
"Very funny!" he said, cringing at his broken endmill.  :D
Mach3 is a mess.
Upgrading will hopefully save you some endmills :)
Offline FXC
  •  45 45
That's right, what other benefit could an upgrade bring? Authentic Scotsman!
How's the v4 coming, dude?
Mach3 is a mess.
V4 is coming along, been a few weeks since Brian sent an update as he is reworking a few things to do with the way FeedHold works but its looking good so far.
Your are not alone as my spindle starts if I stop and start again. Sometimes it starts first go. Using latest version.
Noel
