Hello Guest it is November 11, 2026, 11:15:14 PM
Author Topic: E-STOP on Key Board, Setup  (Read 11608 times)
« on: April 17, 2010, 02:51:40 PM »
Newbie here, I have a question that I would like to have answered by one of you Wizards on Mach3.
My keyboard has a "Emergency" key on the upper left hand corner and I would like to be able to program it into Mach3 as an actual emergency stop for Mach3. The key sequence of this "Emergency" key is <r-Shift>+<F1>. So the questions I have is; Is Mach3 capable of adding this button as an E-Stop if so how can I add this feature into Mach3?
TIA
  •  9,377 9,377
Re: E-STOP on Key Board, Setup
« Reply #1 on: April 18, 2010, 08:25:07 AM »
You could try:-
Config / Ports & Pins / Input Signals / Estop , check emulated, click on Hotkey then press your Emergency key and the value will be entered in the box, click apply.
