Hello Guest it is October 21, 2026, 06:59:48 AM
Author Topic: Program locking up before finishing.  (Read 11933 times)
« on: April 12, 2010, 09:07:04 AM »
Good morning all. Have a problem that someone may be able to solve. I'm running a very long rastering program with a Taig mill and Mach3. My computer is connected to Comcast High Speed Internet. When running the Mach3 program on the mill all other programs are closed. Only Mach3 is running. After about an hour or so, X-axis stops as though it ran out of travel. I have to restart the program near where it stopped using "run from here" feature. All runs well again. Question is, should I unplug internet cable when running Mach3? I'm wondering if McAfee (my security suite) is interfering or should I look elsewhere? I have another processor I plan to dedicate to Mach3 exclusively, but as yet haven't hooked it up yet. Any thoughts? Thank you very much.
Re: Program locking up before finishing.
« Reply #1 on: April 12, 2010, 10:12:20 AM »
Do you have any energy saving features turned on in bios or windows?
« Reply #2 on: April 12, 2010, 10:25:18 AM »
Does it E-Stop or just stop? Are there any messages in the ticker at the bottom of the screen?
« Reply #3 on: April 12, 2010, 02:54:01 PM »
E-stop is activated and error message is driver watchdog tripped. Watchdog is deactivated in config.
« Reply #4 on: April 12, 2010, 03:49:30 PM »
Do the optomisation steps outlined on the downloads page and see if that helps.
« Reply #5 on: April 12, 2010, 11:37:24 PM »
It is an internal alarm in the match, prove disable the antivirus, also Use WatchDog disable en General Config.
regards
