Hello Guest it is November 13, 2026, 07:18:29 PM
Author Topic: Pins 2 & 3 dont work.  (Read 25449 times)
Offline geast
  •  51 51
Re: Pins 2 & 3 dont work.
« Reply #10 on: May 04, 2010, 02:58:50 PM »
Arturod i try the version .036, even the version 1.84.. but exactly the same results.
I forget to mention the the option "Max CL mode enabled" is selected.
« Reply #11 on: May 04, 2010, 04:04:58 PM »
Do you have a Max CL machine?
Offline geast
  •  51 51
« Reply #12 on: May 05, 2010, 03:32:37 PM »
Hello Hood.
I'm using servo drives witch accept step and direction pulses.
This was the only configuration on mach3 that i get the right pulses to my drives.If i don't select it then i don't get pulses i need.
I really don't know what a Max CL machine is.
« Reply #13 on: May 05, 2010, 04:12:11 PM »
Max CL will configure the outputs to certain pins and you cant assign them to anything else no matter what you put in Ports and Pins.
Pins 2 to 9 are quadrature outputs for axis A to Z, ie 2 and 3 are quad outputs for A, 4 and 5 for Y , 6 and 7 for X and 8 and 9 for Z
It would seem that if you are getting motion from your drives on some of these pins with Max CL enabled then your drives are using Quadrature input rather than Step/Dir.
I would suggest you see how to set your drives as Step/Dir and then disable Max CL mode and that way you will be able to configure things in Ports and Pins as you wish.
You will find the Pinouts for Max CL mode here ftp://anonymous@machsupport.com/ExtraInformation/MaxCLPINASSCL.TXT
Offline geast
  •  51 51
« Reply #14 on: May 06, 2010, 12:25:35 PM »
That explains everything, why isn't this documented in the installation manual?
Thank a lot Hood.
