Hello Guest it is November 13, 2026, 09:43:17 AM
Author Topic: Move from tool changer when using wizards  (Read 9289 times)
« on: April 07, 2010, 09:59:14 AM »
I keep getting a move from the tool changer location to the start of a program whenever I use the wizards. I have two machines one doesn't give the move from the tool change location and the other one does. I can't see any difference in the config files. I am using the latest lockdown mach3. I have ignore tool change selected in the general config file. Any suggestions?
Re: Move from tool changer when using wizards
« Reply #1 on: April 07, 2010, 10:43:45 AM »
When I remove the G53 everything is fine but I can't find where it says to include the G53 move to remove it. Also, the other wizard (other machine) has a different format. It lists in comments all of the setting and stuff where the other one doesn't.
