Hello Guest it is November 13, 2026, 11:48:46 AM
Author Topic: fourth axis problem  (Read 9258 times)
Offline xaco
  •  26 26
fourth axis problem
« on: April 06, 2010, 07:32:49 PM »
hi everyone,i have a problem with my fourth axis.....when i write in MDI to rotate it  90 degrees,  it makes 90degrees in mach but in practice it makes  a move of  ..like 98 degrees.......        where can i set that in mach3,so taht 360 will make it do exactly  the full circle.. ?       thanks               Miroslav
Re: fourth axis problem
« Reply #1 on: April 06, 2010, 08:39:50 PM »
You need to set your steps per unit correctly in motor tuning for the A axis. For indexing the units  would be in steps per degree.
