Hello Guest it is November 13, 2026, 12:39:41 PM
Author Topic: conventional vs. climb  (Read 10002 times)
« on: April 06, 2010, 02:49:56 PM »
Problem:
I am using the thread wizard on mach3 and, I not sure which to use. I am making internal threads. It is easier for me to make threads from bottom to top. Should I use climb to thread? Or should I thread from the with conventional from the top down, even though the external treads I will threading onto it will be coming in from the top down?
Re: conventional vs. climb
« Reply #1 on: April 06, 2010, 04:07:18 PM »
Let me reword my problem:
I need help with conventional vs climb thread milling.
I previously made my first thread milling and it worked:
Internal, conventional
I am making another piece that needs to have the same threads.
However, piece I am threading is rotated 180 from the first.
Can I use internal convential to make the same threads? OR do I need to switch to internal climb?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: April 07, 2010, 03:49:00 AM »
I am not sure what you are asking but if you reverse the direction you will reverse the thread e.g. right hand would become left hand.
G02 travelling Z zero to Z minus will produce a right hand thread (clockwise helix)
G03 travelling Z zero to Z minus will produce a left hand thread (anti clockwise helix)
Graham
