Hello Guest it is November 16, 2026, 06:54:11 AM
Author Topic: Help with code problem  (Read 20710 times)
« on: April 04, 2010, 07:24:13 AM »
The code I have included is part of X & Y Zero.
When I use the debugger and step through the code, Dro(0) get set to zero.  When I run the code, it does not get set to zero.  I have tried Call SetDro and Code....
What am I doing wrong.
Code: [Select]
Rem
Rem  Test Code For X And Y Zero routine
Rem
XCurrent = GetDro(0) 'Get current X position
YCurrent = GetDro(1) 'Get current Y position
ZCurrent = GetDro(2) 'Get current Z position
FeedRateCurrent = GetOEMDro(818) 'Get the current Feed Rate
NewFeedRate = 10 'Set Feed Rate for macro
    Call SetOEMDro(818, NewFeedRate)
    Code "(Zero X and Y Macro Running)"
    Rem Find the X negative
    XNew = XCurrent - 2
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos1 = GetVar(2000)
    Code "G0 X" &XCurrent
    Rem Find the X positive
    XNew = XCurrent + 2
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    XCenter = (XPos1 + XPos2)/2
    Code "G0 X" &XCenter
    Code SetDro(0,0)
Re: Help with code problem
« Reply #1 on: April 04, 2010, 10:08:22 AM »
The last statement, "Code SetDro(0,0) is not setting X to zero.
Does that help?
« Reply #2 on: April 04, 2010, 10:33:09 AM »
Instead of
Code SetDro(0,0)
Try
Call SetOEMDro(0,0)
« Reply #3 on: April 04, 2010, 11:18:48 AM »
Greg,
Thanks for the suggestion but that did not work.
  •  9,377 9,377
« Reply #4 on: April 04, 2010, 12:34:32 PM »
It was almost right.
Try:-
Call SetDRO(0,0)
« Reply #5 on: April 04, 2010, 12:35:51 PM »
How about
Call SetOEMDro (800,0)
« Reply #6 on: April 04, 2010, 01:02:22 PM »
Greg,
I found that also, the 800 number.  When I setup through the code it works and the X gets set to zero but when I run the macro it does not get set to zero.  I have even put a pause to give it time to update but that does not help either.
SetDro does the same thing.
  •  9,377 9,377
« Reply #7 on: April 04, 2010, 01:27:36 PM »
You need to pause the macro to give Mach time to catch up.
Try this:-
While IsMoving()
    Wend
Call SetDRO(0,0)
« Reply #8 on: April 04, 2010, 01:38:10 PM »
And it's Gerry, btw. :)
« Reply #9 on: April 04, 2010, 02:10:37 PM »
Gerry,
I should know better sorry about your name.
I will add a while move and see if that helps.
Nils
