Hello Guest it is November 13, 2026, 10:33:37 AM
Author Topic: help with fundamental question  (Read 12140 times)
« on: April 03, 2010, 01:57:37 AM »
Hello,
I go through my usual routine to position and zero the x, y, and z axies.  Then I load a g-code file, and the x,y, and z DROs all read crazy values.  How come?  What do I have to do to keep the DRO's zeroed?  Why would loading any g-code file affect the DRO's since nothing's moved on the machine?   ???
Thanks in advance,
Re: help with fundamental question
« Reply #1 on: April 03, 2010, 04:19:04 AM »
Could be a work offset in your GCode.
« Reply #2 on: April 04, 2010, 09:12:10 AM »
Thnaks, Hood.
I'm a Gcode newbie - what gcode would be specified to cause an offset.  Something is off because when I load the file into Mach, the new x and y are beyond the size of any of the parts. (like 38 inches for X when the extend of the part is only 8 inch o n X.)
If I have the gcode to cut out a rectangle, and then want to cut out a total of 5 just like it, how do I write the gcode to do that?   (if there is a good refernce somewhere to put me to, I would go look at that.)  Just looking at the codes, I don't see one to specify a new offset.
« Reply #3 on: April 04, 2010, 10:30:43 AM »
G54-G59 are for the work offsets.
Can you post the g-code for the part that's giving you problems, and what you're expecting to see?
