Hello Guest it is November 13, 2026, 01:52:58 PM
Author Topic: about pulse calculation  (Read 29036 times)
Re: about pulse calculation
« Reply #10 on: April 03, 2010, 02:09:50 PM »
does it works for closed loop operation ?  --->
http://www.rogersmachine.net/encoderinfo.html
it says that " Alerts the operator of positioning errors on each axis. "
« Reply #11 on: April 03, 2010, 04:08:28 PM »
Its not closed loop as it will not correct the position on the fly, only report errors. All servo drives that you can use with Mach will fault out if a following error limit is exceeded so no real need for that with a servos system.
« Reply #12 on: April 04, 2010, 12:27:19 PM »
thank you, again and again !! now everything is clear..
