Hello Guest it is November 13, 2026, 05:31:11 PM
Author Topic: sporatic motor movement  (Read 10567 times)
« on: April 01, 2010, 07:30:24 AM »
I was wondering if someone could help me. I am setting up a new mill for a friend and all of the axis will not jog, but when a project is loaded, it will sporaticlly move its axis's on some lines of code. The driver board, mill, and motors were all together working earlier. The only change is the computer it is running on. The PC is running XP. I am boggled. Please help as I am trying to get someone new into the sport of cnc, and now I look like the noobie. Thanks sooo much.Andy
Re: sporatic motor movement
« Reply #1 on: April 01, 2010, 12:24:33 PM »
Run the driver test and see what it looks like.
« Reply #2 on: April 01, 2010, 06:16:31 PM »
Driver test was fine. Any other suggestions?
« Reply #3 on: April 01, 2010, 06:25:38 PM »
Check all your wiring is correct and there are no loose connections. If you have a scope have a look a the pulses as you jog.
