Hello Guest it is November 01, 2026, 10:06:35 AM
Author Topic: Two Questions  (Read 11369 times)
Two Questions
« on: October 05, 2006, 08:20:56 AM »
1. When I ask Lazy Cam to load current Mach3 file I get a blank screen, IE no file seems to load up. Is this one item that is not working or something wrong with what I am doing?
2. When I press the right mouse button anywhere in the Lazy Cam screen I get a Round Icon up with 5 items on it, such as one is select primitive. I have to go back and watch the video a few more times but don't remember that being anywhere in it?
3. Ok 3 questions, if I happen to hit the "x" along side of IMPORT, the tool bar runing down the left side goes away. Only way I can seem to get it back is close down Lazy Cam and Mach3 and restart? What the hell am I doing worng there????
Re: Two Questions
« Reply #1 on: October 05, 2006, 07:02:24 PM »
Ok well thanks for the new vedio on Lazy Cam Brain, it did help alot.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Two Questions
« Reply #2 on: October 05, 2006, 07:30:40 PM »
Hi, Jim Neifert
1. nothing wrong with what your do-ing
Some of us are having problem's with the auto file name function, it saves the file in Mach3\gcodefilename.tat it should be
Mach3\gcode\filename.tap.
Turn off auto-filename in LC post options , Save the file under Mach3\gcode\yourfilename.
2. I have not used these features much re-run the video.
3 Shut's down the window don't think there is a way to turn it back on yet.
Hope this Helps, Chip
Re: Two Questions
« Reply #3 on: October 06, 2006, 08:02:17 AM »
Thank you AFN
