Hello Guest it is November 13, 2026, 10:37:04 AM
Author Topic: Estop won't release  (Read 12508 times)
Offline Ben
  •  79 79
Estop won't release
« on: March 28, 2010, 10:38:34 AM »
Mach3 Mill will release the steppers when Estop is initiated but on Mach3 Lathe it won’t. The steppers stop but won’t release. I have to shutdown Lathe and start Mill the get the steppers to release. Soooo what little box is checked wrong or not? Ben
Re: Estop won't release
« Reply #1 on: March 28, 2010, 10:46:01 AM »
What do you mean by steppers release?
Offline Ben
  •  79 79
« Reply #2 on: March 28, 2010, 10:55:41 AM »
The steppers have power to them but not turning they are on hold. If I want to turn the feed handle by hand it won't turn.
« Reply #3 on: March 28, 2010, 11:12:35 AM »
Ok, can you attach the xml for both your mill profile and your turn profile please.
Offline Ben
  •  79 79
« Reply #4 on: March 30, 2010, 06:44:41 PM »
Thanks Hood. I found an old XML that worked and now it's OK. The reason this took so long is my wife's dishwashing machine died. If it's not working I get to do the dishes sooo I spent 2 days taking it apart, all of it, and found a small dish chip stuck under the impeller stopping the main motor from turning. Luckily the motor was OK and I reassembled the whole mess and I'm not doing the dishes. Thanks again, Ben
« Reply #5 on: March 30, 2010, 06:46:57 PM »
;D
