Hello Guest it is November 04, 2026, 01:12:29 PM
Author Topic: tool dro  (Read 16306 times)
tool dro
« on: March 24, 2010, 08:04:40 PM »
I have been using a custom screen set for my router.  I'm having trouble with it changing the tool dro when it calls for a tool change in the gcode. I have a custom macro that depends on this to change.  The standard 1024 screen set changes the tool dro  with no problem.  I really want to use the custom screen set, but I don't know what to look for or what could be causing this.  Any ideas?
Re: tool dro
« Reply #1 on: March 24, 2010, 08:25:07 PM »
You might open your custom .set with Screen4 (or MachScreeen) and verify that the DRO is assigned as illustrated.
Re: tool dro
« Reply #2 on: March 24, 2010, 08:30:18 PM »
I checked, that is set correctly.
Re: tool dro
« Reply #3 on: March 25, 2010, 03:04:04 AM »
Can you attach your screenset and I will see if I can find the problem.
Re: tool dro
« Reply #4 on: March 25, 2010, 08:23:07 AM »
Here it is.
Re: tool dro
« Reply #5 on: March 25, 2010, 10:44:58 AM »
Seems to work fine here, call M6T1 and the DRO changes to 1, call M6T8 it changes to 8 etc etc.
How are you calling your tool?
