Hello Guest it is November 13, 2026, 05:31:07 PM
Author Topic: Touchscreen buttons  (Read 21906 times)
Touchscreen buttons
« on: March 23, 2010, 04:18:17 PM »
I just want to create a touchscreen set where I want to use buttons as a simple keyboard. I will have the numbers 0...9, the letters G, M, F, S, X, Z, I, K +/- . and Enter. So I think I don´t need an on screen keyboard nore a external keyboard.
I tried to use sendkeys "char" but the DROs and the MDI are just shortly flashing with the correct character and than they appear with no change.
Could you please help me with the code?
Dirk
Re: Touchscreen buttons
« Reply #1 on: May 03, 2020, 04:06:05 PM »
Same question here, can´t find any informations about it.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Offline TPS
  •  2,627 2,627
« Reply #3 on: May 04, 2020, 04:15:03 AM »
« Reply #4 on: May 04, 2020, 04:36:59 AM »
@TPS
thank you for the script. Can it be used to do MDI Inputs?
Offline TPS
  •  2,627 2,627
« Reply #5 on: May 04, 2020, 05:08:15 AM »
not directly, you have to add some more Buttons (G,F,and so on) and modify the code
Code: [Select]
SetOEMDro(DRONum,CDbl(Dlg1.FText))
to
Code: [Select]
Code Dlg1.FText
it should do something simular.
